Connecting PS3 to a HomePlug
Discussion in 'Playstation Forums' started by barlee, Feb 9, 2009.
  1. barlee
    barlee
    Feb 9, 2009
    3
    I have a
    BTHomeHub
    85mb Devolo HomePlug Adapter
    PS3
    Can someone please help me to get the PS3 to see the network. I have tried to manually set it giving it an IP, Router IP etc..
    It detects the IP but i do not get an internet connection...
    Any help would be appreciated, when i set up my PC i ran a Install CD which helped, however i assume i can not run the CD on a Playstation..
    Thanks in advance,,,
  2. bladedripper
    bladedripper
    Nov 26, 2007
    5,072
    Birmingham
    +1,527
    I have the devolo on the xbox and ps3 i just connected them on auto and have never had a problem(touch wood)ive also got one on the router(same make?).You could try ringing sony they have just set my brother inlaws up as he was having connection problems.:smashin:
  3. barlee
    barlee
    Feb 9, 2009
    3
    HI
    Thanks, Sods law...
    What i did was went into the ps3 network config, switched from wireless to cabled and selected all the auto settings and had nothing...
    I then tried to set ip's etc manually and still nothing...i will try call sony..thanks...
    any other advice wouild be appreciated...
  4. barlee
    barlee
    Feb 9, 2009
    3
    Yippee!!!
    I decided to do a test, i removed the ethernet that was supplied with the Devolo plug and used the one supplied with my PS3..Worked like a charm...
    Who would have thought...
    Thanks for your help..
  5. Big_Si_Owen
    Big_Si_Owen
    Sep 30, 2008
    1,214
    63
    Royston, Herts
    +239
    I have that exact set up! I'll have a look at my settings....
    I have everything set up on auto, didn't have to do a thing and it worked. sorry I can't be more helpful!
    Si
    EDIT - Cool, I see you have it working now whilst I was fiddling about! :)
