Connecting ps3 to a hdmi capable av reciever.
C
cinema-man
Hi to all
just wondering if anyone can help,if i connect my ps3 to a lpcm capable av reciever via the hdmi will i get the dolby true hd sound and dts master audio,would it be the same as a blu ray player using a bitstream signal.
regards cinema-man.
PSM1
Yes you will get HD audio by connecting as you say.
Whether it sounds the same a bitstream is another matter. Some will say it makes no difference but I feel it will make some difference depending on the reciever you have. Although in theory all recievers should decode the signal the same some do a better job of steering the sound etc. If the signal is already decoded then the reciever can not do this. Now the PS3 may decode better than a cheaper amp so you may be a better sound but then again you may not. My personal preference would be to let the reciever decode if at all possible.
Klipsch The Sevens Powered Speaker Review Coming Soon
Back
