Connecting PS2 to Sanyo Z1 Projector
Discussion in 'Cables & Switches' started by dfield2000, Dec 23, 2003.
  1. dfield2000
    dfield2000
    Jul 16, 2002
    957
    Cardiff
    +5
    I'm sure this must have been asked before - so appologies in advance - but I've done a search and I can't find the answer I'm looking for.
    I'll be receiving my Sonyo Z1 projector in a week, and I need to know that best way to hook up a PS2 to it.
    I presume the best way to output a signal from the PS2 is RGB Scart, but there is no scart on the Z1. If you have one of those adaptor leads that has a S-Vid connection, does the PS2 actually output a S-Vid signal ? Do you have to change some setting in the PS2 menu to tell it you have s-vid lead plugged in the back instead of RGB ? Can I use the component input of the projector ? If so, can someone let me know where I could get the right lead ?
    Thanks.
  2. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    connected my x-box and dreamcast to my Z1 via s-video as I found that there was little difference between the two -S and RGB).
    As s-video was easier I went for that.
    Oh and Pro evolution soccer 3 is awesome on a big screen.
    Cap:)
  3. dfield2000
    dfield2000
    Jul 16, 2002
    957
    Cardiff
    +5
    Are you saying that you can connect a console to the Z1 via RGB ? How do you do that ?
  4. Dave H
    Dave H
    Aug 20, 2000
    4,393
    Lots of different places!
    +144
    You can get a mini svhs plug lead or someone does a ps2 to component lead as well, I'm sure some one will say were shortly.
    Dave.
  5. HappyLad
    HappyLad
  6. dfield2000
    dfield2000
    Jul 16, 2002
    957
    Cardiff
    +5
    That looks like the one I need. Thanks everyone.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    you can get YUV cables for PS2 IXOS do some i think!
    YOu may be in need of a component switcher mate!
  8. HappyLad
    HappyLad
    Please elaborate...
    I think I may need something like this soon.
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    allow more than one YUV source to connect to PJ at once!
  10. HappyLad
    HappyLad
    Do you have these things??
    If so are they cheap??
  11. JUS
    JUS
    Jan 21, 2003
    3,432
    Plute
    +319
    I have a scart switch box (Quattro +) £70ish.
    My GC, xbox and free view scart cables all feed into that. Out from tyhe quattro+ comes a scart and in it goes into a RGB Scart to Component converter. One component lead then goes to projector.
    I decided to go the scart switch box way because scart is more available in the UK so I thought it would be easier to plug new things into it.
    Here's a site that sells a few types of switch box and converters. Switch box is called quintro ...looks like a silver version of my black quatrro.
    http://www.av-sales.co.uk/html/convertors.html
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    there is one in the gaming forum for about £10 its a composite+stereo but works fine for YUV too!
