Peteypops123
I'm renovating my home and after reading reports on here and elsewhere I've decided to install a Hikvision CCTV system with PoE NVR. (i'm new to all the terminology but I think I've got it).
I intend on installing 4 cameras, but for the purpose of future-proofing I believe I need an 8 channel PoE NVR? I haven't really looked into which cameras I need yet, as there seems to be quite a bit of choice. i.e. I understand that the higher the MP = the higher the quality of the picture; but what does 2.8mm and 4mm mean? And do I need infrared on them all? If the cameras are installed at eaves height (2 storey house), and I want good quality pictures at night and day - is there a 'do it all' camera?
Anyway, my main question is... all the Hikvision PoE cameras seem to have a female RJ45 socket. How long is this flex to this? Will it be long enough to poke the camera flex through a 300mm cavity wall so that I connect on the bedroom wall inside the house, or are they designed to be connected outside the house next to the camera - if outside, will the connection be watertight, and do I need to waterproof it in a junction box? (this would look messy).
Any advice on how to connect the camera to the Cat5e cable would be greatly appreciated.
