Connecting Plasma to New Panny Tuner Box.
Discussion in 'Cables & Switches' started by S.S.Dhuper, Dec 31, 2002.
  1. S.S.Dhuper
    S.S.Dhuper
    Hi, My nephews got a Oldish sort of Sony 42inch Plasma and he's going to buy the latest Panny slimline Tuner box, on his sony plasma he's got a montior 14 pin scart connection so he wants a cable which has a 14 pin scart connection on one side and the otherside a normal RGB scart which will go in the Tuner, grateful for any advice.
  2. S.S.Dhuper
    S.S.Dhuper
    Hi there, just to correct my first letter the 14pin connection on the plasma is called VGA, so basically he needs 14pin VGA cable to RGB panny tuner.
  3. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    This will not work. THe panny tuner needs a specific board in a panny plasma. You're best option is pro-v from AV Sales
    http://www.av-sales.com/
