Connecting Plasma->Sky->Sony DVDR->Sony Freeview
Discussion in 'Cables & Switches' started by 911uk, May 18, 2004.
  1. 911uk
    911uk
    Hoping someone can help me connecting the above?
    At the moment, I have a new Sony DVD recorder with an incomming scart from the Sky box and an outgoing scart to the Pany Plasma (via a conversion box). This all works fine - BUT - I've now bought a Sony Freeview box so I can watch a good quality image whist videoing Sky (or vise-versa).
    However, I can't for the life of me work out how to connect this lot together with all my scart leads, it seems that the Sony DVD just doesn't have enough connectors to make it all work!
    Cheers everyone!
    :lease:
  2. chachi
    chachi
    scart switchbox for Sky & Freeview feeding into the recorder assuming the recorder supports recording from one input while displaying another
  3. 911uk
    911uk
    That's an idea, thanks. Can you or anyone recommend a good switch box?
