Connecting PJ to sky
Discussion in 'Projectors, Screens & Video Processors' started by Jack's Dad, Dec 27, 2004.
  1. Jack's Dad
    Jack's Dad
    Dec 27, 2004
    Just set up my Screenplay 4805 to Pioneer 575 via component and picture quality is brilliant.
    I was only going to use the PJ for dvd but as I have a sky digital box kicking around (Amstrad) I thought it might be good to hook this up so I can watch TV.
    I've cabled digital, component and SVideo leads to the PJ which is ceiling mounted, but my sky box doesn't output SVideo.
    How do I go from the scart on my sky box to SVideo on the PJ?
    Thanks in advance for help.
  2. Dazzler2409
    Dazzler2409
    Try a RBG scart to component video convertor (about £80 from Keene, Lektropaks etc)
    I have done this in order to use AV receiver to switch from DVD and Sky to save on sending scart up to pj.
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    Does using your AV amp as a switching device compromise on picture quality? Bit academic for me as the DSP-A5 only takes s-video but at one point I did consider going this route, but then decided a dedicated lead from source to projector was preferable...PJ
  5. Baz1
    Baz1
    Dec 11, 2002
    169
    16
    Workingon, Cumbria.
    Hi There,
    I also have the Infocus 4805, and the only way of getting the best picture from SKY or Freeview is RGB (Scart) through a JS Tech Component converter.
    I have tried the 80 pound RGB to component converter and I sent it back.
    The JS is alot more, but you do get what you pay for, try this and you will NOT be disapointed
  6. Jack's Dad
    Jack's Dad
    Dec 27, 2004
    thanks for the info guys.
    It seems I need to invest in a converter - they seem pretty steep for what they are.
  7. binbag
    binbag
    Jun 16, 2004
    1,717
    North Kent Coast, SE UK
    +81
    How about waiting for a suitable deal on a Sky+ box? Then you can keep n' show your favourite shows. S- Vid and 5.1 source from the box and for most packages £30 per month and above it's at no extra cost.
    As you can tell I think it's a great bit of kit. I got mine on Ebay.
  8. asimm
    asimm
    Aug 3, 2000
    1,516
    48
    +75
    I have Sky + to the 4805 (and sky movies in DD through a sony DVD home ent system). The sky picture is great in movies and in general tv (even in SVHS). Football looks dodgy and I need to investigate. I agree with previous posts - a converter will cost about as much as SKY + - you get SVHS and a PVR!
