Connecting Pioneer DVR-220S to IDTV
Discussion in 'Blu-ray & DVD Players & Recorders' started by Stuart Brooks, Dec 29, 2004.
  1. Stuart Brooks
    Stuart Brooks
    Feb 15, 2002
    119
    16
    It seems that on the Pioneer DVR-220S there isn't a way to select AV1 as an input, and on the Philips IDTV I'm trying to connect it to, digital channel output is only on the SCART which doesn't accept RGB input. Therefore it seems that in order to record DTT and to play it back two SCART leads are required between the IDTV and the DVDR. Has anyone else come across this?
  2. laser
    laser
    Aug 1, 2004
    983
    Hartlepool
    +45
    I have a DVR-220S and Panasonic Freeview decoder. You do need to connect the Freeview decoder to AV2 and select L1 to record off it. AV1 is used for output only. All the setup pictures in the manual only show an output from AV1 to the TV (unless I've missed something).
    Is there a particular reason you are trying to connect a Freeview decoder to AV1?
    BTW Very impressed with the pic quality and recordings from Freeview when the decoder and 220 are set to RGB. The internal analogue tuner is a bit of duffer and looks really crap on plasma and LCD
    :eek:
  3. Stuart Brooks
    Stuart Brooks
    Feb 15, 2002
    119
    16
    It's an IDTV and the Pioneer only outputs RGB on AV1.
  4. laser
    laser
    Aug 1, 2004
    983
    Hartlepool
    +45
    OK.
    What is connected to AV2 then?
  5. Stuart Brooks
    Stuart Brooks
    Feb 15, 2002
    119
    16
    VCR. But using AV2 as the sole connection to the TV means that you lose any sort of playback of DVDs, it's an In only. Also the lack of two-way RGB in any individual SCART socket on the TV means that you need 2 SCART connections between the two. The VCR would then need to be connected through the TV's 3rd SCART.
  6. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    Get a separate Freeview box (circa £30), connect to AV2 then use this for recording. This lets you record in RGB, record whilst TV is off and lets you watch one Freeview channel whilst recording another.
