Connecting personal Minidisc to amp....
Discussion in 'Cables & Switches' started by Ian Carter, Oct 13, 2004.
  1. Ian Carter
    Ian Carter
    Apr 4, 2002
    763
    Swindon, Wilts
    +3
    Not that clued up on these type of things.
    Is it possible to connect a personal MD to an amp using the headphone out on the MD, or does the player need a dedicated output? Pretty sure I've seen a minijack to phono lead somewhere.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    No, the MD player does not need a dedicated output to connect to an amp, but if it has one then the output quality is likely to be a bit better.
    As you say all you need is a cable such as one of These from the headphone jack to any input on a HiFi amp. If you have an AV amp with a spare optical input and an optical output on the MD then you could use one of These instead.
    Mark.
  3. Ian Carter
    Ian Carter
    Apr 4, 2002
    763
    Swindon, Wilts
    +3
    Thanks for your help - didn't want to plug something in that would cause damage.
