C
Claude
Hi there,
My PC has a Radion 8500DV All in Wonder graphics card which has a DVI connection. Upto now the DVI has been used to output to a convetional CRT monitor using a plug in adapter converting the DVI socket into a normal (9 pin or so) monitor socket.
I tried connecting my PC to my PJ via DVI but the PJ is not finding a signal. Do I have to change my ATI settings somehow to output digital, is it anything to do with the monitor type i.e plug and play. If so how do I get around this problem.
