Connecting PC to Sony KE-42TS2E
Discussion in 'Cables & Switches' started by mjb, Dec 31, 2003.
  1. mjb
    mjb
    Anyone know what cable I would need to connect my PC to this panel and where I could get one from? The plasma has HD/VD sockets, not something I'm familiar with, and my PC has both analogue and DVI connections.
  2. mjb
    mjb
    I think I need a VGA to RGBHV Breakout Cable like thisAVCABLE
    I'm already using the composite inputs on the plasma for my DVD, is there something similar to a scart block but for composite?
