Connecting PC to a Sharp
Discussion in 'LCD & LED LCD TVs Forum' started by tarz4n, Feb 16, 2005.
Tags:
  1. tarz4n
    tarz4n
    Hello,
    I've just recieved my Sharp LC32 ga4, and are having some troubles..
    Im trying to connect my PC the the Sharp through a DVI cable (do i need a speciel DVI cable? Mine is a "-" not a "+", but nothing happends on the screen when i select the "input 5" on the screen.
    I can't find anything about this issue in the manual.. please help? thanx :thumbsup:
  2. hoyin
    hoyin
    Go to menu .. and I think under options then under input select - "PC Digital".
    I can't remember exactly where the option is .. but it is somewhere there.
    But that should enable you to view a picture.
