Connecting Panasonic - PWD6BX
Discussion in 'Plasma TVs' started by lconnor, Nov 23, 2004.
  1. lconnor
    lconnor
    Just wanting a bit of advice on connecting my new PWD6BX plasma.
    It comes with the SCART video board and as such I will only have one SCART input, but I have 3 inputs (Video, DVD and SKY).
    The first question is are SCART auto selectors OK, how much quality will I lose etc.. is it worth just using the VCR for this?
    The second question is...
    I am mounting the Plasma on the wall and such I am wanting to chase the cable in the wall to conseal it. The problem being here is that a SCART cable is normally quite thick and will be more difficult to place into the wall.
    Now as I only need video to the display (it does not come with speakers) do I really need to run a full SCART cable to the screen? Can I just use the video signal to he display i.e. SCART to composite and just feed the video to the TV. This will be a smaller cable and easier to fit but will I lose quality?
    Any feedback on this would be good as AV is not my strong point at all..
    Lee
  2. Lizzard
    Lizzard
    There are endless threads explaining how-to connect the Panny PW6 plasma to different sources, use the search function instead and you get lots of results.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
