Quantcast
Connecting Panasonic DMRES10 to a Humax 9200T problem
markdraper
I have a Panasonic DMRES10 dvd recorder and I have connected it to a Humax PVR 9200T, when I play the humax and select AV2 on the Panny, it either comes out with a black and white picture or no picture at all.
I am using a QED Squart scart lead, so not a cheappy jobbie either.
Can you help me, spent ages last night trying to sort it out.
cheers
JayCee
cheers
You need to go in to the ES10s "Functions", "Settings", "Connection", "AV2 Input" and set it to whatever the Humax is outputting...RGB, S-Video or Composite video.
Gavtech
Administrator
It's quite possible that the Humax has output settings that are adjustable too... so ideally you want to set that to RGB, as well as the DVDR.
