Connecting NW-HD3 to car stereo radio/CD player
Discussion in 'Headphones, Earphones & Portable Music' started by Fanboy, Jul 8, 2005.
  1. Fanboy
    Fanboy
    Feb 16, 2005
    25
    I am sure that there were once posts about this subject in here, but I can't find them.
    Does anyone know of a method of connecting a Sony NW-HD3 to a car stereo (radion/CD setup)?
  2. Fanboy
    Fanboy
    Feb 16, 2005
    25
    *Bump*
    Can no one help?
    :lease:
  3. Wykey
    Wykey
    Jul 3, 2005
    46
    You *could* use one of the FM transmitters...
    Not entirely sure of the sound quality though.
  4. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    I think you can get a cable which goes into the back of the head unit. Can't give you any more than that, though.
    Failing that, get a head unit which has a line-in. These are surprisingly rare, though.
  5. philthunder
    philthunder
    Dec 3, 2004
    24
    7
    Midlands
    If your head unit does not have an AUX in Maplin do an FM modulator, this cuts off the aerial feed and sends the line out signal to the radio, it helps by cutting off any radio signals so provides a good signal free from interference. They are much better than the FM transmitters which I found are a pile of poo. You have a power switch for the modulator so that normally off ,it sends the aerial feed straight into the radio, power it up and it cuts off the aerial signal and feeds you aux unit into the radio. Works pretty well and they are £30.
    You put your aerial feed into the modulator and the output from the modulator into the radio, two phono plugs into the modulator from your ipod sony etc. (you will need a phono to 3.5 jack cable in most cases) and power via supplied switch to turn it on and off.
    Set your NW HD3 to line out Tune in the radio to the set frequency and add it to a preset.
  6. Fanboy
    Fanboy
    Feb 16, 2005
    25
    Marvellous - sounds good to me! Thankyou!
    :thumbsup:
  7. Hasselhoffia
    Hasselhoffia
    Well there was supposed to be an official (?) interface kit from Sony (or at least they advertised it in a e- newsletter about 4 months ago) but have not seen it turn up. There are third party products that allow the NW-HD3 to plug in to Sony headunits Try: Connects2.com for their Sony NW-HD1 & Apple iPod car kits
    Blurb:
    Also Revverlution.co.uk. Bound to be more out there.
    You can also try a search on eBay for 'Sony HD3 car kit', usually get a few hits. Try here and here. Little pricey though.
