Connecting Nokia 6230 to PC????
Discussion in 'Cables & Switches' started by SuperOxford, May 31, 2004.
  1. SuperOxford
    SuperOxford
    Dec 4, 2003
    195
    +11
    Whats the bess way to do it?
    Is it the Nokia Connectivity Cable DKU-2 which you can get on Amazon for £19.99 (is that compatible as is doesnt mention a 6230) or should i be using a Bluetooth connection?
    I mainly want to use if for putting MP3 tunes onto the 6230 from the PC
    Your help would be appreciated
  2. rodney_nz
    rodney_nz
    Jun 3, 2004
    105
    +3
    Mate you are better getting a card reader, roughly £10 for a usb2 multireader. Less hassle than the cable. Mate had the cable and had problems and ended up using bluetooth for the other functions (syncing calendar etc). Card reader is faster than cable but sometimes a pain to remove card from the back everytime you want to update
  3. spidermanalf
    spidermanalf
    Oct 25, 2002
    2,000
    63
    Wakefield
    +103
    Get a card reader!
    I could only transfer 1 track at a time via bluetooth! Pain in the backside!
    Card reader is teh way to go!
  4. SuperOxford
    SuperOxford
    Dec 4, 2003
    195
    +11
    Will be buying one very soon
    Thanks for your help
    :thumbsup:
