K
karl
Well I finally ordered a TV for the new house. A Panasonic 37" plasma - TH37PW4B. I got the last one at Sound and Vision for £2400 inc delivery. It went out of stock bu the chap in front of me cancelled.
I have a Philips Q50 NTSC/PAL progressive DVD player on its way from hivizone.
Sky + has recently been installed - S-video + RGB scart.
I will order a panasonic ae100 projector soon.
Now the problem :-
How do I connect it all together for maximum picture quality ?
I understand that progressive output from the DVD player must be fed via component. I expect this means that I will have to swap the component lead from the Plasma to the Projector when I want to use it
A bit fiddly.
I will probably get a Pro V box to improve Sky + on the projector. Does anybody have any experience with a Pro V & a Plasma - Does it improve the picture noticeably ?
I will not be using the projector / plasma at the same time but is there a way to connect them without having to swap leads.
For Sky viewing will the RGB to VGA box be a good choice for the Plasma and the ProV for the projector ?
I think the problem may be one component out from DVD and two displays - Is there a way to split it ?
Thanks for any input.
Now the problem :-
