Connecting N64 to Pioneer Plasma TV
Discussion in 'General Video Gaming Chat' started by Diinky, Mar 2, 2013.
  1. Diinky
    Diinky
    Feb 22, 2007
    142
    +10
    Hi All :hiya:
    Just after a bit of help please.
    I have recently purchased a N64 console and connected it up to my Pioneer KRP 500A plasma tv with a scart cable.
    Now, the picture on the tv is not great to say the least, a bit fuzzy!
    Unfortuntely the N64 console doesnt output RGB, just S Video I think.
    Is the best connection by S Video straight to the Pioneer or can I connect S Video or composite cables to my Denon 2808 amp and upscale the image?
    Would I get any lag by connecting like this?
    Any help would be greatly appreciated.
  2. Loada
    Loada
    Mar 4, 2003
    593
    Guisborough, North Yorkshire
    +51
    S-Video is your next best bet but it's still not going to be great. You can go through the amp but you will incur lag - whether that's acceptable, you'll just have to try it and see. It's probably not going to be great though, it's going to do basically the same job as the Pio.
    An original, native N64 image will always look best on a CRT - if you can get access to one, its the way to go for retro gaming - Sony Trinitron 21" sets can be picked up for literally pounds nowadays.
    Another option is to RGB mod the N64? Might help get a better pic??
  3. Diinky
    Diinky
    Feb 22, 2007
    142
    +10
    thanks Loada, i think i might just sell it!
  4. PFMC84
    PFMC84
    Jan 23, 2008
    2,672
    Ireland
    +390
    Isn't the output cable for the N64 the same as the one for the Gamecube? I'm pretty sure there are RGB SCART's for the Gamecube, perhaps look into getting one of them?
  5. Loada
    Loada
    Mar 4, 2003
    593
    +51
    The main issue is that the PAL N64 does not output RGB without a mod (but the NTSC/USA/Jap/HK ones DO output RGB) - I'm assuming the OP's machine is PAL.
  6. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    I'm running my n64, NES and snes connected via composited to my amp which then sends it to hdmi to my plasma.
    I'm suffering no lag, and even on my 60" screen it looks great
  7. beecee
    beecee
    Dec 8, 2003
    2,329
    2
    117
    Kirkcaldy, Fife
    +506
    UK pal machines do S-video at best, but this was removed for the later models (the coloured cased ones).
    so bog standard composit from them.
    UK pal machines CAN'T be modded for RGB, the only pal machines that could were the launch french ones. (good luck finding one of them).
    if you want RGB then its an import ntsc console you need, and even then they have to be modded for RGB and they dont do it straight from the box.
  8. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    Here's my n64 connected up to my 60" tv.
    Reliving my youth
  9. pRot3us
    pRot3us
    Oct 20, 2004
    6,737
    +5,576
    You're horizontally distorting the image, you need to select 4:3 mode for a correct image.
  10. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    Yeah I know. Just feels good like that.
    I play the snes normally
