Connecting my Tosh RD-XS32 and other bits?
Discussion in 'Blu-ray & DVD Players & Recorders' started by L00py^, Dec 14, 2004.
  1. L00py^
    L00py^
    Sep 23, 2004
    131
    Can someone please advise me on which type and number of cables to connect the following systems together:-
    Toshiba 36ZP48 TV
    Toshiba RD-XS32 DVD Recorder(region 2)
    Toshiba SD-240E DVD Player(multi-region)
    Sky Box
    I am wanting to buy QED only cables as seem to get good reviews.
    With the TV having component output was looking at either Qunex P-CV1(£40) vs Qunex SR-CV1(£77) for connection to the RD-XS32 recorder. Is the £77 worth the extra money on my system?
    Which is the best connection type for sound quality between digital audio co-axial or optical? Could you recommend a QED cable?
    Was just planning to use a Performance Scart P21 to connect the SD-240E, as will only be used now and again. And I guess need another P21 for the sky box system?
    Thanks in advance, PS: as a newbie, so go easy on me :zonked:
