Connecting my system together
Discussion in 'Cables & Switches' started by Legin76, Nov 2, 2004.
  1. Legin76
    Legin76
    Aug 10, 2003
    58
    I have the setup below which I'd like to set up in the best way possible but am not sure what to use and the best way to do it. Any help would be appreciated.
    I have the following
    http://www.projectorcentral.com/panasonic_ae700.htm
    & a Cyrus 7 AMP
    & a DVD Player (Sony thing)
    & Sky+
    & a Media Centre PC
    I want to integrate them all and plug them in - how should I do it? What cables do I need? What would you do - I would also like to AUX it all off to my TV too so I can use that instead sometimes.
    I also would like a decent controller which would control all devices any recommendations.
    I did post this in the hardwas section but got no replys.
  2. lhalha
    lhalha
    People tend to be really helpful in these and other AV forums, but when it comes to describing in detail how to wire up other peoples' whole systems - that's one area where you're not really going to have much luck I'm afraid. With respect, the best advice is to take it slowly and use trial and error to work out what works best for you!
    Cheers,
    Leon
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    AE700...OK lets go Sky via scart DVD via component and PC via Dvi or VGA (quite simple really............or am i missing something?) Pronto or H655 for control
    DOes Cyrus have video conversion or switching
  4. Legin76
    Legin76
    Aug 10, 2003
    58
    Maybe my question is a bit misleading.. putting the cables in is not the problem.. it's knowing what cables etc that will give ne the best result on that system.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Cable types? or brands?
  6. Legin76
    Legin76
    Aug 10, 2003
    58
    hornydragon
    Thanks for your help. I currently only have standard cables and will be getting some new ones. I've heard quite a bit about ixos cables so will get some of those. The Cyrus 7 can not do video :( http://www.cyrus.co.uk/integrated_amps_archive.htm
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    that means its more diffcult to use TV as a secondary display,
    as regards cable dont skimp but dont go nuts either...........
  8. Legin76
    Legin76
    Aug 10, 2003
    58
    I've been looking round and found this site seems to have the best prices and a really good choice. Although I'm not exactly sure which to get... the Profigold 781 seems quite good. same goes for the component cables.
    How would you set it up so I could switch it for the TV? what are the options I can only find switching boxes that have one output.
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  10. Legin76
    Legin76
    Aug 10, 2003
    58
    What about switching it to the tv?
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    well this is where an AV reciver with video switching and dual monitor outputs comes in mate. As you have multiple signal types this is dificult to do well and cheaply.... can just connect VCR scart on Sky to TV etc.................
  12. Legin76
    Legin76
    Aug 10, 2003
    58
    Ok thank you for your help
  13. Legin76
    Legin76
    Aug 10, 2003
    58
    hornydragon.
    Thanks again for your help. I ended up getting the cables from audiovisual online as tv cables athough initially cheaper were £6.50 more expensive once the delivery cost and the hidden handling charge was added. Anyway the cables just arrived. I can't wait to set it all up tonight.
    Got to find a reasonably cheap way to switch it to tv then too. On the other hand I may splash out and get something that is good quality to match the rest of the system (well most of it).
