connecting my second TV to Sky+
Discussion in 'Cables & Switches' started by Ash007, Mar 28, 2002.
  1. Ash007
    Ash007
    Dec 29, 2001
    217
    16
    Rochdale
    I have 2 TVs connected 2 my sky+ box, one TV at the other end of my house. The main TV is connected by Scart RGB, whilst the second TV is connected 2 the RF (i think) so it has a poorer quality picture.
    Is their a way of getting a better picture 2 the second TV?
    If so, which r the best ways? (ps its a long way to the second tv, maybe 20m)
    Cheers,
    Chris
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    I've found the output of RF2 is actually very good all things considered.
    If it isn't upto your standards then maybe a digisender type device or some custom made s-video/scart leads.
    Cable run would be very long but I'm sure it can be done.
