Connecting my pc to plasma (LG-PX11)
Discussion in 'Desktop & Laptop Computers Forum' started by bigval, Mar 12, 2005.
  1. bigval
    bigval
    Dec 30, 2004
    968
    +18
    PC is built, using radeon 9700 pro
    I would like to know how I can connect to the screen.
    Currently I have tried dvi to dvi using 2 dvi adapters and a vga cable.
    Also tried vga from radeon to dvi on screen.
    No signal on both.
    System is working as I have tested on a crt monitor.
    I havent installed any operating system yet but this should not prevent a signal
  2. bigval
    bigval
    Dec 30, 2004
    968
    +18
    ok I now have my video on screen :)
    Only problem I have now is getting audio to the screen from pc.
    I have no amp.
    Anyway that I can connect to screen from the motherboard sound or a soundcard?
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    What sort of audio input does the plasma have? Knowing nothing about plasmas I'd assume it's a normal mono/stereo phono/mini-jack at pre-amp levels, in which case a normal sound card would deliver that.
  4. bigval
    bigval
    Dec 30, 2004
    968
    +18
    Just realised that there is an audio input on the DVI/RGB input part on back of panel. Problem is what is the cable I need?
    It is just a small round jack similar to the back of a pc soundcard output....
    Anyone know what they are called......?
  5. DaveP
    DaveP
    I hesitate to say this but... did the panel come with a manual?
    Dave
    LG Manual
    See Page 12
