Connecting my pc to my projector, help needed
Discussion in 'Cables & Switches' started by danjos, Jul 6, 2004.
  1. danjos
    danjos
    Feb 23, 2004
    211
    hi
    I want to connect my pc (DVI-I output) to my projector (DVI-D input) but i cant find a cable to do this, what do i need ?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    DVI-I is a combined analog and digital interface, you just need a DVI-D to DVI-D cable, ie. ignore the analog pins on your PC's connector.
    This is an example of what you need, I use one to connect my 9600 graphics card to my Z200 projector .. keep the length as short as possible, people often have problems using 10m or longer.
  3. danjos
    danjos
    Feb 23, 2004
    211
    Thanks kragorn :)
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,410
    The Borders
    +3,228
    Hello all
    If you need a long DVI-D cable we supply lots of BetterCables Display Magic cables (9m) to folk who have tried lesser cables and had problems.
    Best regards
    Joe
