connecting my av system in best fashion...
Discussion in 'Cables & Switches' started by keswickboy, Jan 6, 2005.
  1. keswickboy
    keswickboy
    Hi there
    I have a:
    JVC plasma tv (3 scart inputs.)
    Yamaha DSP A2 amp
    Sony HX 900 HDD and DVD recorder
    Pioneer DV 717 DVD player
    Sky +
    Sony PS2
    I would really appreciate advice on the best connection methods and what cables to use for the best possible end result.
    Originally, the amp was set up as a switching box meaning all picture from any input came through on channel E1, depending on what input was selected on the amp remote.
    This is a problem though as for example if i want to record something on sky + and watch a dvd at the same time it doesen't let me.
    Also, currently I'm not using digital optical for the Sony DVD recorder, PS2 or Sky +, what specific type of cable should I use and where will these plug into my Amp - (which ports)
    Any help appreciated.
    many thanks
