Connecting Mac via Onkyo?
Discussion in 'AV Receivers & Amplifiers' started by googlebox99, Jun 7, 2008.
Tags:
  1. googlebox99
    googlebox99
    May 5, 2006
    138
    +8
    I have an Onkyo 605 going to a Toshiba WLT66. I'd like to connect my macbook every so often to browse net on the big screen. What is the best way to do this?
    Through Onkyo, or straight into HDMI or PC on TV? I have no HDMI inputs on Onkyo left.
  2. davepuma
    davepuma
    Jun 24, 2004
    17,520
    +3,505
    I think you've answered your own question! ;) If it's just for occasional use, I would simply connect to the TV and there is no real advantage in connecting a PC via an amp anyway unless it's for the convenience of running a single HDMI cable. What connections are available on a macbook as ultimately that's what is going to be the deciding factor?
  3. googlebox99
    googlebox99
    May 5, 2006
    138
    +8
    Just a mini DVI socket, but would it be better for me to get a DVI-HDMI to the TV, or just a normal VGA cable?
  4. mattg
    mattg
    Jul 16, 2005
    4,289
    Oxfordshire
    +564
    As I understand it, I would recommend going the HDMI route as the signal will remain digital.
    I'm having problems setting my mac to 1366*768 when using the VGA converter. At the moment I can only get it to 1280*768 and have black borders. This is when connecting to a sony KDL40p3020.
  5. dannydj
    dannydj
    May 1, 2007
    5,210
    +344
    if you want sound as well picture id go via the onkyo, as im pretty sure the dvi to hdmi will only provide picture, thus if running straight to the panel an audio lead (3.5 to 2 phono ) will be required.
