Connecting Lumagen Vision to Sanyo Z2
Discussion in 'Cables & Switches' started by UZUBAIRU, Jun 5, 2004.
  1. UZUBAIRU
    UZUBAIRU
    Jul 6, 2001
    570
    28
    Manchester
    +32
    I currently have a Z2 with the following connections:-
    DVD = Component straight to Z2
    XBox and Sky+ = Svideo switched through amplifier and SVideo out to Z2.
    I will soon be getting a Lumagen Vision.
    What cables will I need and how will they be connected to the Lumagen?
    My hubby is in the middle of decorationg the living room and concealing the cables. I need to know soon, so that I can replace cables if needed and he can finish the job.
    Umu
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    A standard vision or one of the new HDP or DVI models? In either case, you can connect to the vision exactly as you do to the Z2 currently, then simply you need either a long vga (or dvi possibly with the newer visions) which goes from vision to the Z2. Easy peasey :)
    ad
  3. UZUBAIRU
    UZUBAIRU
    Jul 6, 2001
    570
    28
    Manchester
    +32
    Cheers buns
