Connecting LCD when Manufac says you cant
Discussion in 'LCD & LED LCD TVs Forum' started by foster111, Dec 30, 2004.
Tags:
  1. foster111
    foster111
    Is there anyway you can connect a LCD TV to a PC when the maufacturer says it has no PC input. The LCD im thinking of buying is the Sharp LC22SV2E with:
    Terminals
    Antenna Terminal (Din Type)
    AV1 Input: 21-pin Euroscart
    AV2 Input: S-Video/Video (cinch)
    Audio (L/R)
    Headphone (3.5 mm mini jack)
    AV output: S-Video/Video, Audio (L/R)
    Is it possible????
  2. will-uk
    will-uk
    how about:
    linky
    or better yet (if you have svideo)
    linky
    :thumbsup:
  3. foster111
    foster111
    s video from graphics card??
  4. mick's cat
    mick's cat
    Yes, my laptop's got it built in. However, it's not worth the bother to connect a computer to a TV of any description this way for any other purposes than say a Powerpoint presentation unless the TV's got a proper VGA or (best) a digital connection.
  5. will-uk
    will-uk
    think my first link didnt work properly...
    so here it is again :)
    linky
  6. foster111
    foster111
    Thank you i will consider this option but may purchase a samsung that supports a computer input
