rattycathy
This relates to another thread:
http://www.avforums.com/forums/lcd-led-lcd-tvs/1254963-lg-m2262d-hdmi-non-pc-support.html
I felt I should start a new thread to broaden the topic beyond one particular model of TV.
It would appear that I am not the only person who makes the assumption that if you have an HDMI output on your PCs graphics card and an HDMI input on your LCD TV that if you were to connect the two using an HDMI cable that you would get a perfectly good picture at the appropriate resolution and that if you also happened to have a blu-ray player in your PC that you would be able to play blu-ray discs through your HDMI ports to your LCD TV/monitor. When I asked in Currys and PCWorld I was told that it was indeed the case. When I telephoned LG and Samsung customer support representatives they also told me that I would be able to connect my PC to their LCD TVs via HDMI without any problems. This is all as it should be surely, HDMI is a standard and all HDMI products should work with each other. However, it seems as though things are rather more complicated than the idyllic scenario I had in my head.
I have been trying to decide between an LG M2262D and a Samsung SM2333HD. I did a little research and found in the LG manual that its HDMI input doesn't support a PC connection, googling found some threads on these forums indicating that LG LCD TVs had an issue with such connections. As I wanted to use the TV as a secondary display on a PC this caused some concern. Further research brought up this review:
PRAD | Review Samsung 2333HD
This says that the Samsung SM2333HD is also unable to use HDMI to connect to a PC stating that the picture is blurred. Although later the review mentions changing the frequencies via a PC using HDMI.
Needless to say confusion reigns. It would be very helpful to myself and the other people on these forums asking such questions, not to mention sales staff and customer support representatives of TV manufacturers if some technologically competent person lurking on these forums could give a definitive answer about this topic.
Can any LCD TV connect to a PC via HDMI to give a good picture at 1080p res?
Is this problem, of producing a blurry picture when connected to a PC via HDMI, limited to LG and Samsung TVs?
Is this problem only limited to certain models of LG and Samsung TVs?
Is it to do with native resolution, screen size, or price range?
Why is it a problem? Surely a graphics card pumping out a 1920 x 1080 resolution at 60Hz through its HDMI port through an HDMI cable into the HDMI input of a TV with a native resolution of 1920 x 1080 at 60Hz should produce a perfectly good crisp picture?
What are the ramifications for playing blu-ray discs from an internal drive in a PC? If it cannot be done through HDMI, are all DVI ports HDCP compliant in all LCD TVs currently on sale?
Please can somebody give a full explanation of what is going on here?
Thank you.
Thank you.
