Connecting LCD Monitor to Freeview box, confused, help please.
Discussion in 'Cables & Switches' started by Richard46, Oct 26, 2003.
  1. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    I know there are lots of threads on this subject but reading them has left me more confused then before.
    I have a 30” LG LCD MW-30LZ10. I am temporarily running it from an old Ondigital Pace box with a Scart to Video cable.
    What I want is the best Freeview picture I can get within reason. I.e. I don’t mind spending a bit of money on a converter box cables etc. I also have an LG DVD/VHS combo (Scart output only) that I want to connect. Quality on this is very secondary anyway as I watch DVD’s on a bigger set up with my Arcam Diva. I mainly want this because I sometimes need to look at tapes for my work, but might watch the odd film.
    Will probably get another Pace Twin for the LG (or one of the new Fusion/Humanex? PVR’s if they appear shortly) as the digital source.
    The LG has S-Video jack
    Y, Pb, Pr, component jacks
    And I quote from the manual
    ‘RGB1 (PC/DTV input)
    RGB2 (Digital RGB input) jack / RS-232C jacks
    -input rgb2 (digital RGB) when input signal supporting DVI-D.’
    The Twin of course has an S-Video output which would be better than the composite video cable I have got at present but I am assuming I could do better. The Twin has a serial output as well, is that relevant? I am totally confused.
    Any help as to which way to go very much appreciated.
    Regards Richard
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    If the LCD has no Scart you need either RGB to VGA or RGB to Component.
    Queue some experts.
    Or buy a component equiped Netgem
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    The netgem is raw sex with component, though I've got a pace twin on s-video myself.... it's not bad. Your rgb capabilities are a bit limited with that panel, and for best possible picture from RGB devices, you do indeed need a RGB-YUV converter, the best are from www.rgbtosvideo.com
  4. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Thanks Martin; Thanks MAW.
    I did not know about the Netgem having Component, so I will think about that, although I did fancy a HD recorder. Think I will wait a 'few weeks' and see what this new Fusion Freeview/HD recorder is like and then make a decision. The Netgem would certainly be a much cheaper alt. especially as I would not need a converter.
    Regards Richard
