Connecting laptop (VGA) to plasma with no VGA in
Discussion in 'Cables & Switches' started by SimonMallion, Apr 7, 2005.
  1. SimonMallion
    SimonMallion
    Feb 15, 2005
    78
    As the topic title says, I want to connect my laptop to a plasma but the plasma does not have a VGA in.
    What are the options available to me?
    The plasma is a panasonic TH42PE50B and has a component input and a few SCART sockets (2 x RGB I believe). The laptop only has a VGA output, not a SVideo as some have.
    Am I able to do what I want? I would like a decent clear picture if possible.
  2. ummy
    ummy
  3. SimonMallion
    SimonMallion
    Feb 15, 2005
    78
    Thanks for the reply and link, I did not know it was that simple.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,353
    Rainham Essex
    +2,441
    Sorry to put a downer on this, but I don't think any of the cables in the link will work when going from PC/laptop to plasma.
    The first converter is to convert RGBs scart to VGA, and I don't think it will work in reverse. All the other leads are connection converters and not signal converters.
    As I said above a scart is RGBs and a VGA output from a PC is RGBHV. To connect one to the other you need to do signal conversion that takes dedicated hardware.
    Mark.
  5. ummy
    ummy
    would the 3phono to VGA work ?
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,353
    Rainham Essex
    +2,441
    No, as I said a VGA outputs RGBHV which is a 5 phono connection. A 3 phono cable will only carry YUV component or RGsB, so unless you can set the laptop to output these signals the lead will not work.
    Mark.
  7. SimonMallion
    SimonMallion
    Feb 15, 2005
    78
  8. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
