connecting laptop to tosh 37wlt66
rphul
what is the best way to connect my tosh to my ibm thinkpad t42p? the laptop has a svideo connection available.
Also any recommendations on where to source the cable/s
gazzer_67
Use the External VGA (D-sub) connector.
rphul
Thanks,
checking wikipedia i take it you mean the rgb connection.
so is that on both the laptop and the tv? the laptop has a svideo output as well.
Also one of my friends suggested that i should run the sound seperately from the headphone socket on the laptop
Probably pay a visit to maplins to get the cables
rphul
hi i have used a vga 15 pin lead to connect from laptop to tv. using the tv as a monitor is fine however when i play an avi via mediaplayer or realplayer the area of the screen where the motion should be is blank.
Have tried the following
- changed resolution up and down on pc
- tried a youtube clip, this played fine
laptop is an ibm t42p
Any ideas ?
viking01
This is just a shot in the dark and here it goes: Start the display properties (Start/Control Panel/Display), go to the 'Settings' folder (last one), click the 'Advanced' button (bottom right). There should be a 'Displays' folder in there. Make sure you select the external monitor here when using the VGA output, and don't forget to select the internal display again when not using the VGA output. One my laptops (one HP and one Sony), this enables realplayer/mediaplayer output on the VGA output.
-Eric-
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
