Connecting Laptop to LCD TV
jellybeanjunkie
Can anyone tell me what leads i would require to connect my laptop (Acer Aspire 4920) to my Philips TV.
I would like to be able to shut lid shut on the laptop and still work on it but via the TV and wireless keyboard, basically like a docking station if possible?
Any advice much appreciated.
A VGA cable should be sufficient. They're pretty cheap.
Cheap Laptops, Hard Drives, LCD Monitors, TVs and more at Ebuyer)
You will need to configure the power options on your laptop to not go into standby when you shut the lid.
I recently bought this:
Nexos 2.4Ghz Wireless Multimedia Entertainment Keyboard with TouchPad - USB - Ebuyer
It runs on 2.4GHz which means the USB reciever does not need to have a 'direct' connection - it can be put anywhere (within a certain distance) - mine works through walls! not that its of any use.
Hope this helps.
Podcast: The Best TVs and Projectors of 2020, plus AV, TV Show & Movie News & Reviews
