Connecting laptop to Denon 3805 - suggestions?
Discussion in 'AV Receivers & Amplifiers' started by ic33, Aug 5, 2004.
Tags:
  1. ic33
    ic33
    I'm looking to buy a new AV receiver soon and the Denon 3805 looks to be the one to go for on features and performance. However I've also been considering the Pioneer VSX-AX5i and the Onkyo TX-NR801E as these offer PC connectivity in the shape of, respectively, USB and Ethernet ports. The Denon misses out in this respect but I was wondering if anyone has any suggestions on how to get a (digital) signal from my laptop to the receiver? I know you can buy external USB soundcards with analogue and digital optical outputs but ideally I'd like to make use of the firewire port on my laptop. I'm just thinking audio at present but being able to send a video signal as well would be a bonus.
    Also, looking at pictures of the 3805 the Denon Link appears to be a RJ45 socket, as used for Ethernet connections. So the question is, with appropriate software, would it be possible to use a PC to 'mimic' a Denon device and use an Ethernet-Ethernet connection?
  2. AgeOwns
    AgeOwns
    Jul 28, 2004
    71
    9
    Macclesfield
    My laptop has a S-video out. I take it you would have check for that.
    I hope to be able to plug it into my Denon 2805...which i pick up from the shop in about 1 hour. Hooray!
  3. ic33
    ic33
    No, no S-video on laptop, just 3 x USB, 1 x firewire, 1 x ethernet, 1 x modem, headphone jack and display output (small D-shaped I think).
  4. ccparkhill
    ccparkhill
    Oct 18, 2003
    507
    London, SE1
    +14
    Not really what you're looking for but it was cheap: I use a Sony PCLK-U5 USB to optical converter I got off eBay for about £15.
  5. ic33
    ic33
    Thanks for the suggestion, that might have been a starting point but I did a search for it and apparently it doesn't work with Windows XP! I'm guessing there might be something similar out there though...
  6. ccparkhill
    ccparkhill
    Oct 18, 2003
    507
    London, SE1
    +14
    It works fine on XP for me, there is also the Sound Blaster MP3+ here.
