Connecting iScan HD to Plasma
Discussion in 'General TV Discussions Forum' started by mattsharpe, May 27, 2005.
  1. mattsharpe
    mattsharpe
    I've been trying everything I can think of to get my system to work and am having very little luck.
    I have a (second hand) Hitachi 32HDT20M plasma, minus its proprieatry tuner box. To solve this I have bought a DVDO iScan HD, which theoretically should provide a signal that the monitor understands.
    I am connecting my Sky Digibox and DVD player through the iScan. I have used a number of leads to get the data from my devices to the iScan, including an S-video lead and a scart-RGB converter.
    The iScan does seem to be receiving the data input - trouble is the screen doesn't seem to be receiving anything. All the screen does is blink its standby light - the screen doesn't even energise.
    There is only a DVI input - I am using a DVI-I lead from my iScan to the screen. Is it worth getting a new DVI lead for instance?
    Any other ideas?
    Thanks!
  2. neural
    neural
    @mattsharpe
    A few things to consider are:
    • Is the plasma functioning properly? Will it work with any source directly plugged into it? DVD or VCR perhaps.
    • Is the DVI-I cable faulty?
    • Is the iScan processing the signal? Look for either a green or blue light on the right hand side of the unit.
    Hope you come right.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    also does the hitachi require an RS232 control? what happened to the tuner? have you tried Hitachi support?
