Connecting Home Cinema And Decoder Help
Discussion in 'LCD & LED LCD TVs Forum' started by boogi11, Aug 16, 2005.
Tags:
  1. boogi11
    boogi11
    hi all, justr bought klv-l32m1 sony tft, and im really struggling, ive connected decoder to scart 3 works perfect, connected pioneer home cinema, svideo from home cinema to scart, (scart 1) and i only get black and white, any ideas
    thanks
    jason
  2. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    yes change the format from nstc to pal or auto,found under setup menu whilst on the correct av channel
  3. boogi11
    boogi11
    thanks, but i cant find an option to change that on the tv menu screens, any suggestions
  4. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    select av1 and then selct menu and set up, a list should come up it could be something like rgb, s-video nstc or pal, keep scrolling until the colour returns
  5. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    or even plug into av 2
  6. boogi11
    boogi11
    ok plugged into av2 and it works, next question is, should sky be in 1 or 2 for best picture, does in make a difference.
  7. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    The problem here has nothing to do with video standards (PAL/NTSC). The problem is that a SCART socket can only be wired for one of two configurations: RGB/Composite or S-Video/Composite. The Sony TVs of course can accept PAL or NTSC.
    But for S-Video, you'll need to plug it into SCART2.
    SKY should be set to output RGB and this can only be connected to SCART1.
  8. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    now im confused, on my own set if it is set rgb but svideo is input i get colours but like a negative :confused:
