Dandandandaman
I am unable to connect my headphones to my tv and would like to know if I can connect them directly to my Sky HD box. If so how would I do it?
I doubt your existing headphones have "red and white" connectors? (Plus the ones I showed have FM radio built in.)
What I meant is could I get some kind of adapter to change the red and white av cables into something that will go into my headphones.
If it is a normal 3.5mm headphone jack then this: 3.5mm Female Stereo Jack to 2 Male RCA Plugs Cable Lead | eBay
(Google and e-Bay are wonderful!)
You will need some form of headphone amp that connects to the audio out of the Sky box (the two rca sockets) and that will amplify the line level signal and give you a headphone socket. Not sure that any of the solutions proposed so far will work. Why don't you ask the question in the headphone section as they will have more info on suitable kit.
There is an input on the headphones where the xbox controller connects with a cable for in game chat so Im hoping the cable you mentioned will work if connected to that from the sky box.
Just for this timeGood idea I may just do it, would there be a problem setting up a new post?
So presumably a microphone out socket.
Post#2 will work, for a tenth of the price of XBox specific gaming headphones.
... and if the cable will work .
Sky Gnome has a headphone socket
The way I understood th OP was that he wanted to connect his headphones to the sky box,a gnome is one way of doing this without trailing wires around the room.Where the heck did that come from? My 1960's transistor radio had a headphone socket but the OP is talking about a socket on his headphones......
