Connecting hardware to a Panasonic TH42PW7B
Discussion in 'Plasma TVs' started by Bof, Dec 7, 2004.
  1. Bof
    Bof
    Nov 14, 2004
    4
    Hi all, new to the plasma scene, i'm wanting to purchase a Panasonic TH42PW7B asap and i'll need to connect some hardware to it. the hardware i'll need to connect to it are as follows:
    Sky +
    Panasonic DMRE85 Multi-Region DVD Recorder
    Yamaha RX-V 650RDS Titanium Receiver
    I realise that the TH42PW7B has 3 input slots on tha back, and that i could probably connect the first 2 items via scart input boards, but what about the Yamaha amp, also are there other ways to connect this equipment.
    Please could someone help me on this matter as i'm wanting to purchase the plasma in the next day or so, cheers Bof. :lease:
  2. docb
    docb
    Nov 22, 2004
    240
    I am in exactly the same boat BOF.
    Only difference being I have the yamaha ax750.
    I want to make sure the PQ from Sky and dvd is optomised.
    I am unsure whether to take the DVD and Sky into the amp and then to screen from amp, or direct to screen with DVD/Sky?
    All replies greatly recieved.
  3. guli
    guli
    Sep 3, 2004
    384
    16
    Get a component board, get a JS rgb to VGA
    DVD recorder to component board, sky+ to js rgb to vga. You'll need a component cable, a vga cable and a scart cable.
    That'll be about the best you can do.
    If you want to route it via your amp, get the component board, get the js rgb to omponent. sky+ to js box, js box to amp via component , dvd recorder to amplifier via component. There is only one component output to screen from the amplifier. You'll need to get 3 component cables and a scart cable as well.
    Alex
