Connecting Grundig Xentia and Pioneer dv-S737
Discussion in 'Cables & Switches' started by Jamesdc, Oct 10, 2003.
  1. Jamesdc
    Jamesdc
    okie doke, having trouble getting a picture from the rgb scart connection (via AV2/DVD). im using the same component - scart cable that was working fine on my loewe xelos before that...so im kinda lost here. ive tried every setting under the sun. at the moment, I have only been able to get composite and s-vid working...really painful :/
    the manual is about as helpful as the plastic bag it came in.
    cheers,
    James,
