Connecting Graphics card to View Monitor and Panny at the same time?
Discussion in 'Cables & Switches' started by MrCoopz, May 21, 2003.
  1. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,069
    63
    +101
    I got a new PC yesterday and in it is a Nvidia Geforce 5200
    http://www.hothardware.com/hh_files/S&V/gffx5200u_benchmarks.shtml
    apparently i needed the "Dual integrated 350 MHz RAMDACs" too view to monitors at the same time but im having trouble getting a picture on the Panny PTAE-100. Do i have to use the S-Video connector to connect them up?
    http://www.hothardware.com/reviews/images/nv34_benches/plate.htm
    I did try the S-Video cable and i did get two pictures the monitor was fine but the one on the panny was black and white, fuzzy and way way off the screen.
    Does anyone know how to set it up?
    Also regarding the Card how do i use the "Integrated TV-encoder"??
    Thanks in advance
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    no idea mate you could try a VGA splitter this would clone the image as oposed to giving an extended desktop.
    S-vid in B&W sounds like a compatibilty problem.
  3. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,069
    63
    +101
    Its meant to output 2 monitors so i dunno whats goin off!!
    How much do these VGA splitters cost and do they lessen they quality?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    noit sure but they are used for all Projection at uni try lindy and see if its cheap try one! VGA should be bettter than S-vid anyway. For PPT they are fine no idea for movies they wont let me play:(
  5. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,069
    63
    +101
    Well i used to use a switcher box and the picture on games and films was great.
    But the picture changed colour now and again, and when ur comfy in bed watching a film and the picture goes green it tends to p*s u off a bit :)
