Connecting games consoles to a projector
Discussion in 'Cables & Switches' started by corky, Aug 9, 2002.
  1. corky
    corky
    Got various consoles that have RGB scart outputs and was wandering how I can connenct these to my Panasonic projector to get the best picture. Have tried the s-video and composite connections which give a very poor picture. My Dreamcast connects to the Projector via a Dreamcast VGA box to the VGA connection and the picture quality is outstanding. Can I get the same quality picture for my XBOX or GameCube? Can I connect RGB Scart to the VGA input via a modified cable, adaptor or something else. Any help would be much appreciated.
  2. paiger
    paiger
    Have a look at www.rgbtosvideo.com I know their RGB to SVHS box is highly regarded and they do RGB to VGA as well.
    S
