Connecting Freeview to Projector
Discussion in 'Cables & Switches' started by petrolhead, Jan 4, 2004.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
    I have a Pace freeview box and a TW100 projector.
    The pace feeds through the video and then on to the PJ using a composite connections.
    Although the picture is ok can improve on this and if so how.
    The PJ has Svideo and coponent although the component is used for the DVD
    If this is posted in the wrong section feel free to move mods
  2. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    I am getting a truly astonishing picture from Freeview using Nebula DigiTV. There is an inherent loss of quality using composite of s-video connections and it would be cheaper to get a new PC with Nebula than fiddling with Pace.
    I am using JVC D-ILA G10 projector and 2m wide screen. The picture from Freeview is marginally below a good DVD (that I also watch using HTPC).
  3. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
    HTPC is a no go for me. Tried it and ended up messing about and nver watching a film :(
    So went back to DVD player and much happier although quality not as good blood pressure is better now :)
    Probably being an IT manager the last think I want ot do is mess on with computers when I get home
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Try a Netgem with component
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
    As stated the component is already used. Does it have svideo as I believe this is this much better than composite
  6. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    I'm using a Pioneer freeview box (£100) with a QED scart to svideo lead on my HS10 PJ on an 8ft screen - very good apart from football that looks a bit patchy
  7. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
  8. calscot
    calscot
    Oct 29, 2002
    665
    16
    Milton Keynes
    Make sure your box outputs s-video first.
    I have my sky box connected to my dvd recorder and then output to the pj with an s-video cable. Not perfect as the cable is 15m long and cheap but not bad. For watching films I record onto DVD+RW and then play it on my HCPC via a vga cable which gives better quality as well as prog scan.
