Connecting external speakers to LG TV
ragavtv
I've been having trouble connecting the TV to a set of external powered speakers. I have attached 3 pictures to show what model of tv it is and what I've tried to do. I'm using RCA cables but no matter where I'm plugging them in, the audio still comes out of the internal tv speakers. Can't seem to find any tv settings option to change that either. Any help would be great, cheers.
pics: Imgur
jmp1975
I don't think it is working as the rca cables are plugged into the input sockets. The only outputs are digital optical or the 3.5mm audio socket I believe looking at the pictures.
Someone else may be able to advise differently but I think it looks like they are only output connection options available.
JayCee
There are no modern TV's made with analogue RCA audio out these days.Your only option is to use the optical out (via a D/A Convertor if your amp doesn't have optical in) or the headphone socket.
dave1956a
pics: Imgur
Looks like the 3,5mm jack is for PC audio IN to the Tv
The only output is Toslink Digital so you need a DAC before you can connect the speakers
See the user manual
Or buy a sound bar with toslink in
Or use speakers with bluetooth, the set uses bluetooth for connecting headphones again see the user manual
http://gscs-b2c.lge.com/downloadFile?fileId=KROWM000219206.pdf
