Connecting everything up!!!
Discussion in 'Cables & Switches' started by Figaro, Jan 18, 2005.
  1. Figaro
    Figaro
    Jan 16, 2005
    24
    3
    I need help please. Recently moved house and now need to reconnect all my equipment. I have a Sony TV with 2 scart sockets. A dvd player, video recorder, and sky box. I also have an analogue aerial. Basically I have scarts going from everything to everything and even have an extra scart splitter. I have a signal boost box and coaxial cables going to other rooms. What is the optimum setup and do I need all these scarts. EG I have 2 scarts from sky box and 2 from video recorder. Where does the aerial input need to be connected to? TV, Video or Sky box?????
    Thanks in advance for your assistance.
  2. dj_johnnyg
    dj_johnnyg
    Right, lets start with the Scart Leads
    Connect 1 Scart lead between the DVD player and the TV.
    Next Connect 1 Scart lead from the Sky Box to the VCR (Could be Marked Decoder or Similar), then Connect the VCR to the TV using another Scart lead using the second Scart socket on the VCR, and the free socket on the TV.
    Right next are the Aerial Leads.
    For this I am going to assume you have the main aerial lead going into the Booster/Splitter first.
    From the Booster/Splitter take a lead into the RF in on the Sky box.
    Connect a lead between the RF out on the Sky box, to the RF in on the VCR.
    Connect a 3rd lead from the RF out on the VCR to the RF in on the TV.
    Hopefully that should work.
  3. Figaro
    Figaro
    Jan 16, 2005
    24
    3
    Thanks for that, i'll give it a try and hopefully everything should work!!!
    I have noticed that since when I go to the programme menu in Sky, then select a programme to watch, the 'smart' setting whicjh autoswitches to widescreen etc nolonger works and the pictures are distorted. Any idea why this is happening?
  4. dj_johnnyg
    dj_johnnyg
    Try swapping the Scart leads into the back of the TV
  5. stevomacca
    stevomacca
    Jan 27, 2005
    266
    ok, i might aswell hop onto this thread.
    i'm about to buy an optoma rd50 and denon dht550sd, i also have a ps2, sky+ and a sharp vcr.
    i'll also be connecting the tv to my pc for dvds etc.
    i have no idea and am complete noob so can you please tell me what cables to buy and pref where to buy them (uk).
    cheers
