connecting dvd to amp
Discussion in 'Cables & Switches' started by mulder, Jan 14, 2003.
  1. mulder
    mulder
    Dec 9, 2002
    146
    Can anyone help!!
    I own a yamaha dsp ax620 amp and a toshsd2109 dvd player connected together via a coaxial lead as there is no optical connections on my dvd player, the problem is I want to buy a philips dvdr880 but that too is only connected via coaxial and I don't have any other coaxial sockets left on my amp is there anything I can do? besides buying another amp that is!!
  2. driver8
    driver8
    Nov 17, 2002
    191
    Malé, Maldives
  3. Alsproject
    Alsproject
    Nov 12, 2002
    163
    +7
    Well, if you wanted both digital co-ax cables to connect to the one Co-ax socket, you could first try out a co-ax Y plug. You should be able to get one of these from any hi-fi store but I don't know if it will work properly. It still might be worth trying as it will only cost a couple of quid.
    Alternatively, you can get a Coaxial To Optical Convertor for about £20 from www.lektropacks.co.uk (just do a search for COOP). Then you could connect it to the optical connector on the amp.
    Hope this helps.
    Alan
  4. mulder
    mulder
    Dec 9, 2002
    146
    Thanks for your help guys coaxial to optical converter looks good!
  5. JFK
    JFK
    Apr 6, 2002
    208
    middlands of no return
    +11
    You dont need any coaxial to optical converter. I have the same amp and with my first dvd player only being coaxial output.
    Look in the manual on page 35 at the grey hilighted section
    4 I/O ASSIGNMENT then look for - 4D COAXIAL IN (for the COAXIAL INPUT jack) the initial setting is CD but you can change it to DVD or if you follow the sequence of buttons to press on the remote below.
    Press 4 times on the Menu/Setup button
    1 time on the +> (right arrow) button
    6 times on the V (down arrow) button
    3 times on the -< (left arrow) button
    4 times on the ^ (up arrow) button
    Now all you have to do is select DVD on the input selection and watch and listen to movies.
  6. mulder
    mulder
    Dec 9, 2002
    146
    jfk, How will that solve the problem of two coaxial leads and one coaxial socket?
  7. JFK
    JFK
    Apr 6, 2002
    208
    +11
    Sorry about that, didn't read thread properly. Maybe there is a coaxial Y-splitter or back to the idea of the converter.
