Connecting DVD player
keestramper
I want to connect a DVD player on the best method.
I have on the DVD yellow, blue, green, red and black and also red and white for audio
The TV have greeen, blue, red, white and red
Can i use a yellow, red white kabel to HDMI or are scart a beter quality
gibbsy
I'd use a component cable. That gives a far more stable connection than having a component to HDMI converter or indeed scart.
Amazon product
The three gang cable is used for video and the two gang for audio. Colours will match those on your player and TV.
gibbsy
no the tv dont have the yellow colour
Doesn't matter. Connect the same colour at both TV end and into the DVD player with the three video leads. Do the same for the two audio leads.
Seb Briggs
Yellow is a separate video connection (composite) and would give the worst quality
as above component connection is best red, green and blue for video then red and white for audio
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
