Connecting dvd player using HDMI ??
Discussion in 'Plasma TVs Forum' started by Fontie, Jul 29, 2005.
  1. Fontie
    Fontie
    Dec 7, 2004
    196
    Yeading
    +11
    Ive just got a Samsung 950 dvd player and cannot get a picture connecting with hdmi to my Samsung H5 all i get is a light blue screen. I conected using component and it works fine. Anyone know why it wont work using hdmi :confused:
  2. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    something in the setup menu on the dvd, i think you need to turn on digital output maybe?
  3. Fontie
    Fontie
    Dec 7, 2004
    196
    Yeading
    +11
    I dont know what im doing wrong here the tv see's the hdmi because when i turn the dvd player on the no signal disapears but all im left with is a light blue screen and the hdmi light on the dvd isnt lit only the progressive. im missing something easy here i can feel it just dont know what :suicide: Help please
  4. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    Faulty cable, faulty socket maybe or a faulty dvd player. Try taking the dvd player to a retailer to try.....
  5. Fontie
    Fontie
    Dec 7, 2004
    196
    Yeading
    +11
    I was afraid you'd say the faulty word. When i pluged the hdmi lead into the dvd it was a tight fit but when i pluged other end into the tv it wasnt nearly as tight a fit. I'll do as you say and take the dvd to currys or comit and see if it works but ive a horrible feeling its the H5 hdmi socket thats faulty.
    I just looked at the hdmi socket on the TV and it looks like one of the small gold contacts has bent back into the socket :rolleyes: it must have been standing sightly proud and i caught it putting the cable in. Ill have to have a closer look to-morrow as there's no one here at the moment to help take it off its stand. Im hoping i can caefuly bent the contact back, Would this be covered on the warranty the tv is only 16 days old.
    Theres no way i could do anything with this the contacts are pushed right back into the socket and i cant even see where they should lay. Im going to phone DigiUK and get this sorted under warranty all i did was plug in the lead and this has hapened or it was like it :eek:
