Connecting DVD player to OLD television
Discussion in 'Blu-ray & DVD Players & Recorders' started by The-Grinch, Mar 8, 2005.
  1. The-Grinch
    The-Grinch
    Hi All,
    I have a very old television that only has one input, an aerial socket. I also have a DVD player with two outputs, scart and RGB.
    Any ideas how I can get the DVD player to play through the old TV?
    Any comments suggestions appreciated.
    CHEERS
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,803
    Somewhere in South Yorkshire
    +6,412
  3. The-Grinch
    The-Grinch
    Thank you nige! for 30 quid i might as well buy another TV.
  4. Strider123
    Strider123
    Dec 8, 2004
    23
    You need to go Scart to VCR then use the aerial socet out to the TV.
    Thats only way I think you can do it m8.
  5. The-Grinch
    The-Grinch
    scart to VCR eh? i'll give that a go tonight. Thanks!
  6. LV426
    LV426
    Jul 14, 2000
    13,803
    +6,412
    You can try it. However, I suspect that you may encounter Macrovision (copy protection) artefacts. It depends on the VCR.
