connecting dvd player to av receiver
Discussion in 'Blu-ray & DVD Players & Recorders' started by tvhustla, Jul 9, 2005.
  1. tvhustla
    tvhustla
    Jan 4, 2004
    41
    can someone confirm whether or not i will need to connect my dvd player to my amp to the multi ch in L,R, RL, RR, SUB, CEN with analogue cables if it is already connected via a single coaxial cable?
  2. Mark_a
    Mark_a
    May 27, 2005
    3,066
    +617
    Once connected via a digital link you shouldn't need to connect by analogue as well. I certainly don't with either my Pioneer DVD recorder or my Panasonic DVD player.
    Regards
    Mark
  3. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    It depends if you play DVD-Audio/ SACD disks through your DVD player. If so, then connecting using the 6 analogue connectors will probably give you a better quality sound than using the coax. You should till use the coax for regular DVDs though.
    Balders.
