I've just purchased a Samsung Q60AA QLED TV, to replace my old Panasonic Plasma.
I've had the plasma for quite some time and it's been hooked up to an analogue Technics SA-AX710 amp to provide sound to my external speakers. This worked fine as the Panasonic had a 5mm audio out.
As I'm sure you'll all know, the new Samsung TV doesn't have any analogue ports on it but has HDMI eARC and optical audio capabilities, as well as Bluetooth.
I bought a small box the other day, which I thought would do the trick of converting the digital signal to analogue, so I could continue to use my amp but so far I've been unable to get it to work.
The box has HDMI in and HDMI, phono and optical out. It also has a selector for pass, 2 channel and 5.1.
I also have a Panasonic Blu-ray player that has a optical and phono on it, not sure if that could be used to get things to work.
I'm sure some will say just get new kit etc but I'm not in the position to do that just yet or get rid of the stuff that still works well, after 25+ years.
Any help would be greatly appreciated.
