J
JIMAKROS
I connected the AV1 of the digibox which says it will output RGB signal to the AV2 input of the panny.Then i went to the connections menu and put both AV1 and AV2 of the panny into RGB.You would expect to record an RGB signal, right?But i get nothing,no picture with only the sound recorded.Any advice here please?
